Edelbrock Preformance rpm insug
Edelbrock 750
Kam med följande data:
Part Number: CCA-CL12-238-2
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,300-5,600
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 270
Advertised Duration: 262 int./270 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.462 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.469 in.
Valve Lift with Factory Rocker Arm Ratio: 0.462 int./0.469 exh. lift
Lobe Separation (degrees): 110
Är helt novis med detta om toppar så all hjälp med topprågan är mkt mkt upskattat. Gärna om pris ovh leverantör oxå.
MVH Jerker
