Mer delar finns. Mejla för komplett lista
1st 1179 Heater core C2 63-67 1670 såld
1st Heater core med Ac C2 63-67 1470
1st 102142 Stenskottsskydd C2 63-67 340
1set Skyddsmatta Brun C2 63-67 960
1set 632016 Door window seal C2 -64 390
1st X2442 Instegslist +2st beg C2 63-64 290
1st A3303 Bezel Auto shifter C2 65-67 350
1set 542090 Paint protector decklid C2 63-67 340
1par 407520 Solskydd (63 cupe C2 63-64 cab 1360
1st 393231 Bränslemätare C2 65-67 1090
1sats Glas instrum.m tätning C2 63-67 1340
1par 39154 Torkararm C2 66-67 1180
1st 2120 Blinkerskontakt C2 64-66 790
2st 28423 Relase cable decklid C2 63-67 100
1set Dörrlist innre cab C2 63-67 830
1sats 22167 Spiklist cab C2 63-67 660 såld
1st 424520 Armstöd Bl (Beg OK) C2 63-66 1386
1st 1519 Fläktkåpa 427 C2 66-67 3220
1st 3840083 Spolarbehållare C2 63-67 224 såld
1st 42107 Licensbraket front C2 63-65 540
1st 0095 Slangklämm kit correkt 427 C2 66-67 380
1set 25277 Nutplate C2 63-67 560
1set 33401 Scew kit C2 64-67 160
1st 33686 Clips C2 63-67 420
1st 1567 Shifter bezel C2 64-67 190
1st 1298 Shifter lockout C2 64-67 430
1st 562157 Cancel cam ex.tele C2 64-66 250
1st 2235 Cancel cam tele C2 63-66 250
1st 332317 Clips set windsheld cupe C2 64-67 760 såld
1st 562165 Cancel cam tele C2 65-66 420
1st 592009 Capacitor parklight C2 63- 375
1st 192026 Lock bromsbeållare PB C2 65-66 350
2st 192049 Stop pin parkbrake C2 63- 75
1st 262727 Decal valvcover 327HP C2 64-65 50
2st 26912 Vev vent window Black C2 63-67 280
1st 1372 parag Vent window regulator RH C2 65-67 2890
6st 0718 Clips fönstervev C2 63-67 15
1st 33082 Speaker custom dual C2 63-67 550
1st 1737 Grill bracket kit C2 65-67 150
1st K1242 Fann clutch nut set C2 63-67 30
1st 252071 Lamp holder heater C2 64-67 240
2set A8062 Clip sparkplug wire C2 63-67 140
1st K1084 Nut set decklid latch C2 63-67 50
1st 33988 Clamp kit Trans cooler line C2 63-67 50
4st 38949 Retainer sparkplug wire C2 65-67 60
1st A2935 Front bow conv. list C2 63-67 275 såld
1st A2924-63 Rear bow conv. List C2 63-67 410
1st 43155 Pillar post cupe list C2 63-67 540
1st 43157 Rear vent cupe list C2 63-67 580
1st E6718 Wiper switch C2 65-67 640
4st 130085 Windov upper stop conv C2 63-67 125
2set 232177 Radio panel clip C2 64-67 120
1st K1086 Door panel clip/scew kit C2 65-67 85
1st 2120 Turn signal switch no tele C2 64-66 500
1st A8332 Oilfiller tube C2 64-65 350
1st 30387 Bult P brake C2 64-66 42
1st 30385 Clevis P brake C2 64-66 140
1st Fuelfilter +braket C2 65 175
1set A2721 Gasket cov lock decklid C2 63-67 60
1st 49919 Turn signal Cansel cam C2 64-66 75
1st Clock knopp C2 85
1st 800043 Shifter slide Aut C2 65-67 75
1st Cigg ligth house C2 30
1set Emblem nut C2 65 100
1st Decal radiator Harrison C2 65 75
1st 562320 Power steering braket C2-C3 65-82 880
1st 1808 Bultkit bakaxel komplett C2-C3 65-68 2590
2st X2464 Adjustable stutrod C2-C3 63-79 1650
Massor av Bussningar mm Bakvagn C2-C3 63-82 ring
Massor av Bussningar mm Framvagn C2-C3 63-82 ring
Hjullager satser fram o bak C2-C3 63-82 ring
Massor av Bromsdelar +handbromsdelar C2-C3 63-82 ring
Div Kylarslangar C2-C3 63-82 ring
1set 482021 Clips seatcover C2-C3 63-82 115
Massor av Scew kit olika satser finns C2-C3 63-82 ring
2set 1722 Bussning cab/ht pin C2-C3 63-68 50
1st A9332 Trans mount auto C2-C3 64-82 185
1set 352353 Gas line kit C2-C3 64-69 100
2st A8296 Air cleaner flame restrictor C2-C3 64-72 50
4st 40109 Parkbrake cable guide C2-C3 65-82 40
1set 39561 Brake pad pin C2-C3 65-82 295
1st 20479 Nut front spindel C2-C3 63-82 125
1st 440106 Grease cap front C2-C3 63-82 70
1set K1242 Fan clutch nut kit C2-C3 63-73 45
1set Bumper A arm lower C2-C3 63-82
1st Balk rear strutrod C2-C3 63-82
1st Beg Bezel Auto shifter C2 65-67 100
1st Beg Fäste elantenn C2 65-66 250
2st Beg Inner door handel L+R C2 63-67 325
1st Beg Gaspedal C2 63-67 150
1st Beg Mittdel stötfångare fram C2 63-67 500
1set Beg Avgasupphängning C2 63-67 500
C2 delar utförsäljes
www.classiccarservice.se
Service,Delar och Tillbehör samt renovering av Corvette
Tel o Fax 046-705969 info@classiccarservice.se
Re: C2 delar utförsäljes
Jag är intresserad av Gaspedalen om den finns kvar ?
Söker även lister och hörn till framrutan till C2 .
