1set Matta fram Svart loop C3 68-76 3665
1sats Tankband C3 68-74 400
4st Trimring C3 68-82 395
1st 23049 Airduct C3 76-81 290
1st 44646 Fan clutch C3 74-79 2160
533030 Translock cable man C3 69-76 780
533214 Translock cable aut C3 69-77 780
213050 Spedo cable man C3 69-77 425
2st 28423 Relase cable decklid C3 68-75 100
3st Gaswire C3 68-77 400
2st Tatch wire C3 68-73 380
1st 453134 Heater cable (temp) C3 69-76 480
1st 3966626 Hoodrealese cable C3 69-76 890
2set Spoiler m montkit C3 68-72 865
1st Rep kit instrumentpanel bl. C3 70-76 1590
1set Door window seal inner C3 -68 780
1par 405547 Pillar post Royal blue C3 71-72 860
1par 405653 Pillar post Dark sadle C3 70-72 860
1st 133134 Armrest Black C3 68-82 599
1set 23010 Dörrlist C3 -68 1440
3st 42945 Dörrlist cab C3 69-75 840
1st X2306 Gummilist T-Top C3 77-82 1790
1st 2282 Gummilist rear window C3 68-72 640
Div gummilister C3 68-82 ring
1set 133915 Gummimatta C3 68-82 525
1st 2470 Fläktkåpa SB C3 69-72 3220
1st 1519 Fläktkåpa 327 auto/ 427 C3 -68 3220
1set 133980-14 Targa väska C3 68-82 575
1st 3840083 Spolarbehållare C3 68-70 224
1st X2032 Dörrhandtag Yttre V C3 69-82 450
1st X2094 Dörrhandtag Yttre V C3 -68 790
1st 41455 Innre dörrhandtags mekanism C3 68-77 990
10st 29092 Packning ytre dörrhantag C3 68-82 30
1par 7660 Stoppning Nackstöd C3 68-69 480
1st 147 Kromkåpa fördelare C3 68-70 1440
2st X2445 Instegslist C3 68-77 690
1st X2043 Krom lock luftrenare C3 66-72 750
1st Krom lock luftrenare 454 C3 68-74 500
1set 23007 Kromsarg avgas SS C3 68-69 1190
1set 51639 Kromlist Targalucka C3 68-76 920
1set 603022 Plast bussning Targalucka C3 68-82 140
1st 23187 Decklid lås R C3 68-75 1080
1st 603107 T Top latch RH front LH rear C3 68l-76 1080
1set 408015 Solskydd L saddle C3 70-72 1260
1st 25025147 Oljetrycksmätare C3 78-82 840
1st 395231 Oljetrycksmätare C3 72-73 960
1st 1993495 Clutch neutral switch NOS C3 69-81 990
1st 143192R Innerskärm RH rear C3 74-82 1995
1st Trueflex Rear bumper m montkit C3 74-82 4500
Mer delar finns Maila för komplett lista
1st X2306 Gummilist T-Top C3 77-82 1790 såld
1set 133915 Gummimatta C3 68-82 525 såld
1st 395231 Oljetrycksmätare C3 72-73 960 såld
1st 323078 Exh braket 2,5” TH 400 C3 68-78 690
1st 6410206 Kylarlock GM orginal C3 68-72 300
1st X2554 Vacumtank C3 68-82 790
10st 0718 Clips fönstervev C3 68-82 15
1st A9332 Trans mount auto C3 80-82 185
1st Balk rear strutrod C3 68-82
3st 23804 Tändlås cyl C3 68-78 280
2st 23813 Door lock set C3 69-80 450
1st 43236 Luggage rack hardware C3 68-75 620
1st 373018 Astrovent seal kit C3 69-76 196
1st 603089L T-top list ss C3 70-77 560
1st 603089R T-top list ss C3 70-77 560
1st X2068 Qvarter panel ret conv. C3 68-69 650
1set 333105 Kromlist framskärm C3 68-72 750
1st 1480 Bonding strip C3 68-73 420
1st 1481 Bonding strip C3 68-73 420
2set 333106 Clips molding C3 68-72 90
2st X2423 Knop seat C3 70-78 110
2st 133740 Sunvisor pin C3 77-79E 125
3set 483007 Rep kit trimpanel C3 68-77 480
5st 2009 Parkbrake seal C3 67-76 80
1set 4335-2 Door Armrest repair black C3 69-77 680
1set 2319 Rear comp. Door hinge C3 68-79 480
2st X2245 Grill defroster C3 68-77 490
1st X2546 Shifter boot black man. C3 68-76 320
1pr 4146-31 Shift Console Side Trim. Oxblood C3 73-75 960
5set 43227 Mount kit door panel C3 68-77 140
7st 2347 Door panel velcro C3 68-82 45
3st X2420 Door panel retainer C3 68-77 30
4st X2466 Lock knop C3 68-77 180
2st X2026 Door glas antirattle C3 69-96 490
3st 283067 Door glas roller C3 68-72 245
1st 29834 Shift knop aut crome C3 65-82 350
1st 483291 Hanskfackslåda C3 68-76 1120
1st 41829 Body gasket C3 70-72 420
4st 442065 Adjuster kit Headligth C3 58-82 250
3st 242013 Radiator rubber C3 66-75 250
4st 373025 Gasket bakljus/kaross C3 68-78 130
4st 373026 Gasket Bakljusglas C3 68-73 160
1st 603002 T-Top repar kit C3 78-82 400 såld
2st 203118R/L Stag kofångare C3 72-73 560
2st 203104 Bultsats stötfångare C3 68-72 250
2st B4561L Stag stötfångare C3 68-72
1st 333067 Spoiler mount kit C3 73-79 270
3st 343155 Screwkit T-top C3 70-77E 52
1st 34305 Screw kit grill C3 70-74 110
1st 352180 Choke cover C3 66-70 140
2st 353084 Choke spring C3 68-70 240
1st 353093 Choke rod C3 69-- 153
1st 353091 Choke cover C3 70-74 195
1st 153037 PVC gromet C3 75-88 55
10st 663221 Lamp adjuster C3 68-76 25
3st 7805158 Kugghjul tändlås C3
1st 7808385 Issolator C3 70-89 135
1st 563110 Horn kontakt W tele C3 67-82 340
1st 253051 Knop headligth switch C3 72-76 310
2st 562108 Horn kontakt C3 63-68 155
1st 192292 Block bromsrör C3 63-82 220
1st 192291 Block bromsrör C3 65L-82 360
10st 192051 Clips brakecable C3 63-82 65
2st 193036 Bromsljuskontakt sriker C3 69-75 250
2st 193136 Retainer parkbrake shoe C3 65-82 90
19st 272104 Shims fördelare C3 62-74 35
1st 272119 Axel fördelare C3 62-74 1080
1st 272107 Drev fördelare C3 62-74 370
3st X326-72 Drev varvräknare C3 62-74 490
3st 272106 Knop drev varvräknare C3 62-74 130
1st 263208 Dekal console L88 C3 69-- 280
8st 533750 Clips clutch pivot nutlockc3 C3 63-81 40
1st 532752 Boot clutch cover C3 63-81 175
1st 532738 Pivot stud clutch link C3 63-81 220
1sats Komplett Koplingsreglage C2-C3 63-82 1500
20st X230-55 Door hinge Spring C3 68-82 125
1st Inner door handel R C3 69-- 175
7st 283012 Repair spring doorhandle C3 69-82 125
3st 34024 Door Sill Water Diverter. RH C3 72-77 240
3st 34023 Door Sill Water Diverter. RH C3 72-77 240
C3 delar utförsäljes
www.classiccarservice.se
Service,Delar och Tillbehör samt renovering av Corvette
Tel o Fax 046-705969 info@classiccarservice.se
