Årets julklappar på väg !
Tekniska frågor och svar om Corvetter 1963-1967
Användarvisningsbild
bjerka
Inlägg av bjerka » fre nov 29, 2013 21:10
När tomten kommer hem finns risken att frugan drar :D
Corvette Light Bulb, Interior, # 1816, 1963-1974 25448 $1.99
Corvette Engine Compartment Wiring Harness & Vacuum Hose Strap Kit, 1963-1964 41863 $18.99
Corvette Engine Wiring Harness, With Air Conditioning, 1963 A9379 $195.99
Corvette Forward Light Wiring Harness, 1963 A9315 $168.99
Corvette Power Window Wiring Harness, 1963-1966 32937 $127.99
Corvette Aluminum Radiator/Fan Module Assembly, With Small Block, 1963-1972 49847 $799.99
Corvette Radiator Hose, Lower, Small Block, 1963-1965 A3568 $45.99
Corvette Bypass Hose, Small Block, 1963-1967 A9860 $9.99
Corvette Radiator Hose, Upper, For Cars With 327ci/340hp, 360hp & 375hp Engine, 1963-1965 A3553 $32.99
Corvette Aluminum Radiator Upper Mounting Cushion, 1963-1972 A5556 $5.99
Corvette Upper/Lower Radiator Mounting Cushions, 1961-1972 A1655 $2.99
Corvette Tachometer Cable, With Gray Case, 1963-1964 25665 $19.99
Corvette License Plate Light Lens, 1961-1967 A2218 $21.99
Corvette Bumper Bolts, Rear, 1963-1967 A8153 $39.99
RAGGTOPP Convertible Top Cleaner 88-0253-1 $13.99
Corvette Assembly Manuals, 1956-1982
Please Select 1963
Corvette Monospring Kit, Rear, Composite Replacement, 1963-1977 A7130 $389.99
Corvette Ignition Switch Nut, 1960-1965 A8040 $9.99
Corvette Power Antenna, Flush Mount, Without CB, 1963-1989 32891 $89.99
Corvette Rubber Floor Mats, Black, 1963-1967 A1404 $32.99
Corvette Fender Gripper Fender Cover, Black, With C2 Logo 42023 $22.99
Corvette Battery Retainer, 1963-1967 31086 $13.99
Corvette Battery Hold Down Bolt Kit, 1963-1966 31540 $10.99
Corvette Steering Wheel Mounting Screws, 1963-1982 A5577 $4.99
Corvette Steering Column Bearing Kit, 1963-1966 A3287 $39.99
Corvette Upper Steering Column Bearing, 1963 A3285 $27.99
Corvette Heater Core, Without Air Conditioning, 1963-1967 25194 $99.99
Corvette Heater Case Seal Kit, 1963-1967 53169 $31.99
Corvette Heater Box Gasket, 1963-1967 25455 $8.99
Corvette Motor Mount, Black, Urethane Zinc Plated, 1963-1982 54580 $44.99
Corvette Body Speed Nut Kit, 1963 41855 $5.99
Corvette Rear Body/Lights Wiring Harness, Convertible, Without Back-Up Lights, 1963 A9262 $214.99
Corvette 5-Speed Transmission Conversion Kit, Tremec TKO, 1963-1982 A4274 $3,999.99
Corvette Dash Wiring Harness, Without Back-Up Lights, 1963 A9259 $489.99
Corvette Clutch Pedal Return Spring, 1963-1967 44489 $7.99
Corvette Muffler Hangers, Rear, 1963 A8400 $79.99
Corvette Rear Exhaust Panel Bolt And Nut Set, 1963-1973 25-11001 $11.99
1963 C2 med eller utan tak...
Ricky
Re: Årets julklappar på väg !
Inlägg av Ricky » fre nov 29, 2013 23:33
Bra jobbat dær Bjerka! :mrgreen:
2011 - KM Oldies Bild
2012 - KM Oldies Bild
2013 - KM Oldies Bild
2014 - KM Oldies Bild
bjerka
Inlägg av bjerka » lör feb 22, 2014 22:20
I veckan kommer containern !! Sen ska det skruvas så det står härliga till !
Dessutom blir motorn klar i början av veckan :D
magnum
Inlägg av magnum » sön feb 23, 2014 8:34
:D
bjerka
Inlägg av bjerka » ons feb 26, 2014 22:43
Idag var jag och hämtade mina grejer, julafton.
Inventerat och klart, som vanligt var varenda liten mutter med :D
Den här pjäsen ska bli kul att åka med i sommar B)
Jag kunde inte låta bli att börja muttra på studs, så nu är bakvagnen ihopskruvad med nya kolfiberfjädern och allt...
Motorn är på gång och hämtas i helgen som kommer, sen ska den upp i bänk och justeras innan den stoppas i.
Smuggler
Inlägg av Smuggler » ons feb 26, 2014 23:32
Härligt med så många nya delar!!!!
Lådan kommer du att bli nöjd med. Ge den bara 100 mil att gå till sig på så börjar den mjuka upp sig.
Kom ihåg att byta olja i lådan redan efter några kilometers körning. Det är vansinnigt med dynga kvar i dessa från tillverkningen, jag vet...
Byt sen igen vid 30-40 mil. Sen kan man nog känna sig lite lungnare. Jag bytte tredje gången vid 100 mil, men det är jag det.
Hansen Racing har GM Synchromesh olja som du skall ha till Tremeclådan.
Ös på med mer bilder efterhand du monterar delarna, roligt att få hänga med på!
/Daniel
Corvette 427-69
Camaro Z28 -71
Smuggler 24 -85
Harley 750 -46
bjerka
Inlägg av bjerka » tor feb 27, 2014 7:42
Jag läste det nånstans har jag för mig, det var kanske du som skrev det. Att det var svarvspån i nya lådan. Jag kommer öppna upp min och kika lite och även skölja rent.
Tusen tack för tipsen !
bjerka
Inlägg av bjerka » tor feb 27, 2014 19:32
Tomt blev det
Ut med det gamla....
...och in med det nya
